Austin Spectra roof mount
snowman3725
Im looking to mount an Austin Spectra mag mount on the roof of my house, or attic, not sure which one yet. However the NMO mount has a 17' lead of RG58 cable ending in a BNC male connector, and i have to extend this to about 75', but the RG58 extension cables over 12' are UHF males to BNC males. Do i have to use the RG58 cable all the way? Cant seem to find any adaptors that will make this work.
Fast1eddie
Crafton Pennsylvania
Seventy-five feet is awfully long for RG 58 due to signal loss. Suggest you use RG 8 or similar for the longer run, Universal radio sells pre made cabling with your choice of connectors. Excellent quality and have never had any problems.
snowman3725
Would an LMR-240 cable be suitable?
K4RBT
LMR-240 is the same size as RG-58 and will have a little less loss, but still a bad idea for uhf. Go with LMR-400 (RG-8 size). I would also look in to a better connector for the RG-58 unless the BNC is going to
be inside, they are weatherproof, but only to a point.
Fred Mahone
K2KOH
Putnam County, NY
You might want to invest in a Larsen NMO ground plane kit...check out AES website, I believe they sell them on there.
