Austin, Texas Scanning Question
F15Duke
Austin, Texas
Recently got a BCD 396XT and have programmed TCSO and Austin Fire using Simulcast 1 and 2. Most reception is broken and I probably need an external antenna. The APD reception is very good using the city freqs. Any suggestions on programming or suggested antennas. Thanks
Russell
Texas DB Admin
Dallas Texas
Austin PD is a strong signal simulcast system and less antenna is probably in order. Uniden has a firmware update coming out that should help, as well. I found that successful reception of Austin/Travis is very location dependent. When I was there on a State gig, my residence was terrible but my office was exceptional and they were only five minutes apart. I found that the little race stubby came in handy in the bad location and the regular antenna worked well in the good location. YMMV. It is extremely frustrating.
Russell
texasemt13
CenTex DBA
Hunter, TX
I agree with Russell on multiple accounts. Less antenna (the discontinued RS race stubby antenna especially) is usually the best medicine. The receiver overloads because the signal is so strong in places. It is very frustrating, but dealing with antennas is better than no scanning at all.
mikepro96fan
Austin, Tx 78750
I use the 800mhz antenna, get perfect reception Pro106..Nw Austin off of hwy 2222 my homebase..try moving scanner near a window perhaps..
LFRfreak
Mount Juliet, TN
I live in Bee Cave. My PRO-106 was having a rough time until I switched to the RS race stubby antenna. Reception isn't perfect, but it's a major improvement. Do you guys have any programming tips having to do with MultiSite mode, AGC, control channels, etc. to further boost reception?
Furthermore, does anyone monitor the system with a PRO-96? My PRO-96 seems deaf compared to my PRO-106.
rbarker
Robert
Austin, TX
I scan with a Pro-96 and a Pro-2096 and they work fine. But it's just like the others said. You can move the antenna 2 inches and it makes a huge difference. For the handheld I use, the 800Mhz antenna that Radio Shack sells 800MHz Scanner Antenna - RadioShack.com For the base radio, I just use the antenna that came with it and i only have it extended about 6 inches.
