Australia (AU) License Data for DSDPlus FMP24
thewraith2008
This is the initial release of the DSDPlus/FMP24 AU License Data (FMP-FreqList.csv)
It has only been tested with DSDPlus (FastLane) v2.98.
If earlier versions use the same .csv file format, they should work.
To use this file, after downloading unpack the ".7z" with 7-Zip.
Backup your existing "FMP-FreqList.csv" to another location. If you currently use it.
The only file needed from zip is "FMP-FreqList.csv"
I recommend copying the "FMP-FreqList.csv.log" as well for versioning purposes. It also has some processing stats in it.
Using FMP-FreqList.csv:
With DSDPlus/FMP24 stopped.​
Copy FMP-FreqList.csv to your DSDplus working folder​
FMP24.cfg:
- Update "search origin" line to your location. This is a must to show frequency info in YOUR area.​
- Set "search distance" to about 50 KMs (Or whatever you RX area is. Larger will show more but it can be to much)​
Restart DSDPlus/FMP24
Enjoy.
AU License Data
May 10, 2018 ACMA* data was used to create updated FMP/FMP24/FMPA-compatible CSV file.​
Coverage:​
DC to 1800 MHz:-​
- States: ALL and individual state files (QLD,NSW,ACT,VIC,TAS,SA,NT,WA)​
- Only frequencies with emission bandwidths H, K are listed.​
- LICENCEE and LOCATION are processed to reduced length, where possible.​
- LICENCEE where possible has replaced/removed certain keywords.​
(eg. remove = "PTY LTD") or (eg. replace "Australia" with "Aust.")​
- LOCATION where possible has been reduced to "PLACE, STATE"​
- SECOND EMISSION MODE is utilizied to display "TX POWER and if TX/RX Frequency eg. 50W -TX-"​
Download (Single 7z file with 1 csv file for all AU: (approx 2.2 Mb)​
Download (Single 7z file with 1 csv file per state eg. QLD,NSW,ACT,VIC,TAS,SA,NT,WA): (approx 2.35 Mb)​
Limits of this type of file is that one frequency may have multiple entries in your area. DSDPlus I think shows the closest, which may not be the right one. Current solution would be comment out (use ';') unwanted entries.
Another nice feature in a up and coming version of DSDPlus FL (v2.1xx) is the displaying of heading. Useful for those of us that use a rotatable antenna. Shown in image as "179 deg".
Let me know what you think.
* "Based on Australian Communications and Media Authority information"
7-zip used because it was almost double the compression of a .zip
vkkev
Thanks Heaps for that,
Have loaded and works great, i uses DSD + a lot and it just got a whole lot better thanks to your hard work. Can i post this news to other forums linked back to here?
Regards
Kev
thewraith2008
This is a updated release of the DSDPlus/FMP24 AU License Data (FMP-FreqList.csv)
AU License Data
June 1, 2018 ACMA* data was used to create updated FMP/FMP24/FMPA-compatible CSV file.​
See 1st post for details and usage.
Is anyone using this data. How are you finding it. Is it helpful in identifying unknown signals?
