Automobile Bluetooth
radio3353
Pairing the G4 with an automobile Bluetooth system...anybody try this yet with success? I am going to try this on my 2014 Toyota Corolla when I have a chance, but I thought I would ask if anybody else has done this yet in their auto. Thanks.
kibler
No but......
Today my wife and I took a little drive and she uses her cell phone and connects with her car audio system and it sounds totally amazing as she can connect to and play my Scanner Feed! She has a 2016 Honda CRV and I had no idea you could do this???.....I have not a clue how to set this up, I can not do this in my old truck! Thanks
stevez97
Myrtle Beach, South Carolina
I've tried to pair my G5 with my Lincoln MKX and the Ford (Lincoln) Sync DOES find the G5, however, provides a five digit pin, whereas the G5 only accepts 3 digits. Hmmm................" so close, yet so far."
Has anyone discovered a workaround for this?
Citywide173
Attleboro, MA
I got it to pair with my 2010 Escape's SYNC, but it rings like an incoming call before every transmission. This is a known issue with bluetooth headsets, so I wasn't surprised. Needless to say, it wasn't useful.
radio3353
I have said it before...if only the G4/G5 had a headphone jack.:mad: Then it would be so simple to pipe it into an automobile's aux input jack (or use headphones at home) instead of fighting Bluetooth.
mike4nzix
If you have a standard "line-in" jack and "aux" setting on your factory car radio, may I suggest a Bluetooth adapter that is wired to the line-in slot? I have found these solutions to be much easier to pair for other devices and do not ring or have an audio alert like factory units when there is incoming audio. Fewer headaches and it never pairs when you don't want it to. Plus, this solution allows a dedicated phone to remain paired with the head unit.
Any of these will likely provide what you're looking for at little investment:
https://www.google.com/search?q=blu...j_XaAhUl_4MKHaQkBVYQ_AUICigB&biw=1280&bih=653
krokus
Southeastern Michigan
Will the Unication pair with it?
Sent using Tapatalk
N6ML
My G5 pairs with my ~10 year old JVC aftermarket head-unit.... but it has the usual issue where it disconnects and reconnects for each voice message, so it loses some of the audio each time ... it's somewhat usable for long messages, but not really usable for rapid-fire, like police dispatch, etc.
lsh1885
Orlando, Florida
I read a post somewhere that Unication devices will only work with Bluetooth 2.1, can anyone confirm this.
radio3353
Thanks, Mike. I have this Bluetooth adapter at home that I use to pair the G4 with an external speaker:
https://www.amazon.com/gp/product/B01FDI8VBI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
It works well. Not sure I want to drag it and the associated cable to the car every time.
I had no success pairing the G4 to my 2014 Toyota Corolla's Bluetooth. Guess I will just use the internal speaker for the few times I take it mobile.
radio3353
That is true. See my post above for the adapter I use to pair my G4 to an external speaker. It works well. The G4/G5 will pair with it. It uses Bluetooth v2.1.
lsh1885
Orlando, Florida
Thanks I will try it. What I am trying to do I have a Sony digital audio recorder that is not Bluetooth that I would like it to work with my G4
mike4nzix
Most welcome! I hope to have some source material regarding Unication and Bluetooth on deck when my G5 arrives.
N6ML
Received a "Docooler 2-in-1" today (via Amazon Prime). It seems to work (with the G5) better than my JVC head-unit and my Altec Lansing portable speaker - minimal, if any, truncation of messages. If only it would turn on automatically when external power is supplied, I could bury it behind the dash, but it seems to need the button to be pushed to power on. It does power off automatically when BT has been disconnected for 10 mins.
lsh1885
Orlando, Florida
I bought the docooler Bluetooth transceiver from Amazon but having trouble getting it to connect with my non-Bluetooth device it pairs with the G4 OK but when I switch from receive to transmit it doesn’t go through I am supposed to have it hooked up to the red 3.5 jack correct?
N6ML
Connect to the black jack, and use "Receiver" mode. The G4 is the BlueTooth transmitter, and the Docooler is the receiver.
