leahannnn said:
Hi, could use some help. Just got a BD92xlt so I can hear my husband why he is at work. I can't figure out what freq are out there for MCSO, and Surprise PD. Any one know theses? I have found a million, but none seem to be updated. Also what are "talk groups" the numbers by these listings don't require a decimal point and I don't know if they go into this scanner or not! Thanks a bunch..
Both MCSO and Surprise PD are on the county's Motorola Trunked Radio System. Your BC92XLT is not capable of following this type of system. Take a look at
http://www.radioreference.com/apps/wiki/index.php?title=Trunking_Basics for an overview of what trunking is.
Surprise PD is analog on the trunked system, so any low-end "TrunkTracker scanner" (available for about $130 on up) will do. MCSO, on the other hand, uses Digital talkgroups which require a digital scanner to monitor. A digital scanner (new) is around $500.
Your BC92XLT is capable of listening to non-trunked activity in metro Phoenix, including Phoenix Fire and most other valley fire departments, including Surprise FD.
You may want to look at the Southwest Frequency Directory (SWFD),
www.ArizonaScanner.com. This is a locally-edited book published by my company, Scannerstuff. SWFD is a single, comprehensive, and highly-accurate book of just about anything you'd want to listen to in Arizona, and includes users guides to get you started, frequencies to tune to, and information on how to "interpret" what you are hearing.
Dan
