Background noise when transmitting TGIDs
ESF-12
Edmonton, Alberta
Apologies if this is the wrong section to post this.
Regarding transmitting TGID in the feed.
Scanners: (Radioshack Pro-18 & Grecom psr-600c) I've attempted to transmit TGID on my feeds (successfully) but with considerable background noise (with or without incoming signal) with the data cables plugged into the computer, no background noise when cables are plugged into usb charging block. Using the stock data cable for the Grecom but not the Pro-18.
Is there a solution to eliminate the background noise? Cables, adapters, different usb ports? Even tried a different computer, same result.
New to the broadcasting part of scanners.
