Background noise
Mason69
Doesn't play well with others
Banned
Carthage, Tennessee
whenever there is a signal coming through, and someone is talking, i can hear noaa weather radio in the back. idk why?
kc2asb
NYC Area
Is this happening on every channel you are monitoring and across bands (VHF, UHF, etc)? The intermod I would get from the weather broadcast was only happening on VHF high. For fun, I would try unplugging the antenna and putting the radio in weather mode. If you are able to pick up a weather broadcast with no antenna, you likely have a station in very close proximity to your location.
tvengr
Well Known Member
Baltimore County, MD
I checked and I do not see a NOAA weather transmitter in Carthage. Mason69, are you close to a FM broadcast or TV station transmitter?
