J-WeB
Is there always background static sounds or a little bit of humming? I installed a radioshack ground loop isolator and it didn't seem to change anything noticeably. Is there a specific direction it needs to be installed in? Is it possible it's a bad isolator? The sound is like an engine in the background, a real fast "whom whom whom whom" sound... However it isn't the cops engine because it happens even when dispatch is picked up.
I would also like to know if there is interference between scanners and other equipment such as routers, modems, or telephones. When I listen to the scanner itself and not my feed, it sounds for the most part crystal clear.
