Backlight Settings on my 668
kibler
Hello...This is not a big deal, but a few days ago I played around with Backlight Settings in EZscan and set the MODE to 'Key Press' & 'Key Press' so the display Backlight would not come on until a channel keyed up! This worked great for about 3 or 4 days, but then failed and light stopped coming on! The voice comes on but no light? I reloaded new configuration settings, but still not working like it did! Any ides that I could try? Thanks
kibler
Swipesy.....I would have thought that loading new configuration to this Folder would have 'reset' ever thing, but it had no effect?????......yet????
buddrousa
LModeBAT/Backlight Settings-Mode (Batt) Controls how the backlight operates on battery power. Default is Key/Key Press.
LModeEXT/Backlight Settings-Mode (Pwr) Controls how the backlight operates on external power. Default is On.
Note: see also Backlight Mode/Light for object backlight settings.
On - backlight is always on.
Stlth - backlight is always off.
Norml - backlight turns on when the power key is pressed for the amount of time set in LiteTime.
Key/Key Press - backlight turns on when any key is pressed (and used) for the amount of time set in LiteTime.
Ignor - works like 'Key' but the key's normal function is ignored for the first press. Pressing any key again (when the light is on) will activate that key's function.
Scanner Press or to select On, Stlth, Norml, Key, or Ignor.
Software General Settings > Backlight Settings > Mode (Batt and Pwr)- On, Stealth, Normal, Key Press, or Ignore First Key Press.
LiteArea/Backlight Settings-Area Controls what is lighted. Default is Both.
Both - lights the display and keypad.
LCD - lights the display only.
Keybd - lights the keypad only.
Scanner Press or to select Both, LCD, or Keybd.
Software General Settings > Backlight Settings > Area- Both, LCD, or Keys.
Contents
LiteTime/Timeout Controls the amount of time the LiteArea stays on when LMode is set to Key/Key Press, Ignor, or Norml. Default is 5.
Scanner Press SEL or to edit. Enter the number of seconds, 1 - 99.
Press or to select the first digit, then to move the cursor and select the second digit.
Press SEL to save and exit.
Software General Settings > Backlight Settings > Timeout- 1-99.
LiteLevel/Backlight Settings-Level Controls the brightness of the backlight and (if enabled) the Alert LED. Default is 4.
Scanner Press or to select Low, 2-10, or High.
Software General Settings > Backlight Settings > Level- Low, 2-10, or High.
Easier to Read Pro-668/PSR800 Digital Scanner and EZ-Scan/iScan Software Manual
Wackyracer
Hi buddrousa... Sorry I'm not sure what you mean! Thanks
under the general tab in ezscan.....
Under backlight settings set Mode (Batt) to Keypress
Set mode (pwr) to ON
This will keep the backlight on while plugged in and scanning. But running off the battery you will need to press a key to have a backlight.
kibler
Thanks for the reply and information buddrousa! The settings that I used (and it only worked a few days) is just like Wackyracer suggested! Thanks for the suggestions
Michael-SATX
San Antonio, Texas
Random Question that perhaps affected your backlight Op ?
Hmm, did you by chance upgrade your RS Pro-668 with the world famous Whistler 1080 DMR Upgrade ?
If yes, what versions do you now show after pressing the MENU key during the Welcome Startup Screen ?
Example:
uP Appl Ver:U3.8
DSP App Ver:3.0 / DSP Voc Ver:1.8
DSP build# 101
RR Lib Ver: 503
Do Tell ;)
kibler
Example:
uP Appl Ver:U3.8
DSP build# 101
RR Lib Ver: 503
Do Tell ;)
Do Tell.....the iScan/EZScan Program Software 'Backlight' settings are almost identical and in my opinion has nothing to do with whether the Scanner Backlight works as intended! Thanks
