ProScan: Bad imports 19.4
dave3825
Suffolk County NY
This morning I imported some conventional analog freqs and instead of ctcss or dsc tones, it imported and set every entry with a color code of 0 . I went and tried Sentinel and that's when I discovered Uniden was having ftp issues with Sentinel. I figured the @ProScan error might have been related.
Now at 3 30 pm, Sentinel is working and this is what Proscan is doing. Seems its with any conventional I import from the rr database. Trunked systems looked fine.
Reconrider
Inside the Galaxy
Radio Galaxy
It should be easy to fix that. I think if you click the fave list it will give you the option to change it from dmr/trbo to conventional. If you're able to change it, the color code 0 should say search
