mlevin said:
That's what that TG was called in the old radios. The TG IDs and useage have stayed the same. Just a new bandplan for the new radios
Motorola trunking radios are broken down by a number of zones and 16 channels per zone. Depending on the radio, the zones will be labled alphabetically and the channels numericly. Or vice versa with the zones be labled numericly and the channel alphabetically. This seems to be radio specific though. Maybe someone can eleborate.
This is true. For example, in the PD radios there is a 16 channel selector knob and a A/B/C switch. Depending on what settings these are in determines what the talkgroup is.
Example
A1 = Wilkens Precinct 1 Dispatch 101
B1 = Wilkens Precinct 1 Tactical 201
C1 = Wilkens Precinct 1 ISU 301
The above would be true if you left the channel knob in the 1st position and flipped the switch down from A-C. When organized this way all the precinct talkgroups are together and all the talkgroup types are together. Therefore everything at channel position 1 would relate to wilkens and everything in switch position A would be a dispatch talkgroup, ect... hopefully this verbal explanation has helped...if i get a chance to ill post a picture of the top of my radio and label which is which. I have no idea about the FD radios though, i was unable to download that new chart so i couldnt see what the plan looks like and im not sure if my previous explanation holds true for FD radios.
[Edit]: In the PD we dont refer to the TG's by the location name (like A1) we refer to them by a specially assigned number, like 101, 201, 301 ect...
