Band Pass Filter
BFIFM790
Im hoping someone with a technical background can help me in this field. Listening in the New York Metro area naturally brings intermod and front end overloading easily in open scanning modes. I see that Scannermaster has both the VHF band pass filter and the FM Notch Filter. Does anyone have suggestions on if any of these would be useful in a mobile scanning application where its a 396XT connected to a mobile antenna in the car?
Any insight would be appreciated
Thank you
ronhl
Live Free or Die St.
intermod issues
Thank you
I live in the city and such a strong RF environment i had so much intermod coming thru on VHF that made it very annoying to scan that band.
So on my base antenna main feed i have all 3 in series, 152,159 mhz Par notch filters along with a FM band notch and it made all the difference in the world. I can finally again enjoy the VHF Hi Band.
Also keep in mind front end rf overloading isnt good for our very sensitive receivers/scanners either. Because it will desense them and make them useless in capturing the weak distant signals. So yes, these filters are a must for the serious mobile or base listener...... if you did a search in these forums you will find allot of us are using them.
Hope this has helped
Ron
lmrtek
notch filters are very narrow and are used to attenuate a very narrow range of frequency without attenuating the intended frequencies.
Bandpass filters are usually designed to pass a wide range of frequency while attenuating everything outside that band width.
You can make your own notch filter with coax and a Tee connector
A open coaxial stub becomes a nitch filter
When shorted on the end, it becomes a bandpass filter
And it costs you a few cents worth of scrap coax.
prcguy
A coaxial stub is always a notch and never a band pass.
A 1/4 wave OPEN stub will notch frequencies which are 1/4 wavelength in cable minus the velocity factor of the cable and will also notch odd multiples of that frequency.
A 1/4 wave SHORTED stub will notch twice the frequency which is 1/4 wavelength minus the velocity factor of the cable and will also notch even multiples of that frequency.
A common lightning arrester for repeater sites is a 1/4 shorted stub which will not affect the desired frequency passing through but will otherwise short out the center conductor of the coax to ground.
prcguy
