Does anyone know what band plan to program for (1) Collin County Public Safety and (2) Dallas City Local Government on an SDS100?
I am using these settings for both:
Custom band plan 1, 851.0250 base, 854.0000 upper, 440 offset, positive polarity, 25khz spacing
Custom band plan 2, 851.0125 base, 868.9875 upper, 0 offset, positive polarity, 25khz spacing
For the
Dallas Local Government System,
no band plan is needed. For a 'rebanded system', where
all of the system frequencies have a
5 in the fourth decimal place, you do not need to enter a band plan. The system will track correctly without one.
For the
Collin County Public Safety system, you
do need a band plan, because one or more of the system frequencies has a
zero in the fourth decimal place,
The correct band plan tables for both Uniden & GRE/Whistler scanners can be found on the
Rebanding article in the Wiki,
wiki.radioreference.com
As you probably know, the Collin County system is being phased out, and is being replaced by a layer on the P25
PAWM system. No band plan entry is required for a P25 system, as that the scanner will receive information needed via the system;s control channel data.
The Dallas LG system is also slowly being phased out. Individual departments are transitioning to the Dallas P25 Simulcast system. Once the new system is fully operational, the old system will no longer be needed. I have not seen specific statements on whether some of the current analog system's frequencies will be utilized on the new system, nor whether the old system might be kept as a backup to the new system.
