[BAND PLAN MATH] Trunk Recorder - Find Median Band Plan
melona380
Lincoln, Nebraska
I'm trying to use trunk-recorder to record site 28's traffic from this system
South Dakota State Radio System Trunking System, Statewide, South Dakota - Scanner Frequencies
Custom Frequency Tables For System 2315
Base Spacing Offset
155.41500 15.0 380
157.20000 12.5 436 *
157.47000 15.0 454 *
*The 2nd and 3rd Entry's apply to our freqs
We need to cover
site Channel FREQ
28 449 157.3625
28 592 159.5400
28 608 159.7800
28 617 159.9150
28 627 160.0650
ALL Freqs ex. 449 work with:
Base Spacing Offset
157.47000 15.0 454
Channel 449 Needs this band plan:
Base Spacing Offset
157.20000 12.5 436
The following is from the github page for trunk recorder:
-bandplan - [SmartNet only] this is the SmartNet bandplan that will be used. The options are 800_standard, 800_reband, 800_splinter, and 400_custom. 800_standard is the default.
-bandplanBase - [SmartNet, 400_custom only] this is for the 400_custom bandplan only. This is the base frequency, specified in Hz.
-bandplanHigh - [SmartNet, 400_custom only] this is the highest channel in the system, specified in Hz.
-bandplanSpacing - [SmartNet, 400_custom only] this is the channel spacing, specified in Hz. Typically this is 25000.
-bandplanOffset - [SmartNet, 400_custom only] this is the offset used to calculate frequencies.
^We can only add each of there once per system or it breaks :(
our current config is as follows:
"systems": [{
"control_channels": [159780000,160065000],
"type": "smartnet",
"talkgroupsFile": "/opt/trunk/ChanList.csv",
"shortName": "LakeDigital",
"bandplan": "400_custom",
"bandplanBase": "157470000",
"bandplanHigh": "162045000",
"bandplanSpacing": "15000",
"bandplanOffset": "454"
AGAIN WITH THIS WE CANT GET CHAN 449!
***SORRY ABOUT ALL THE JUNK HERE IS THE REAL PART ;) ***
My Question is since we have 4 channels on one band plan and 1 on another bandplan, is there a mathematical middle we could compute?
I have made a very crude excel fuzzing calc if you want to play with it: https://transfer.sh/Tfy6k/BP CALC.xlsx
I want to stay away from making the different band plan channel 449 its own system in trunk-recorder!
**NOTE
I am aware that RR says we do not use Channel# 449... but I promise you a lot of our traffic goes over it
Site Name County Freqs
028 (1C) Madison Lake 159.540 159.780c 159.915 160.065a
Our Fix for the software Request is : https://github.com/robotastic/trunk-recorder/issues/138
talkpair
Clinton County, MO
It cannot be done using a single line from the band plan.
It seems strange that the program won't accept multiple lines, because the 800 mHz rebanded plan contains more than a single line in it's plan.
