SDS100/SDS200: Bandplan Setting
dwh367
Amateur Radio Operator
Owensboro, KY (Daviess County)
I've manually programmed an 800 P25 Phase 2 simulcast system that is not in the database. This is my first ever attempt at manually programming it. When I scan it's seeing the control channel so I think I'm good so far. I've done a lot of searching first but what I can't seem to find an answer to is if I need to also edit the bandplan or if it's good at the defaults (all zeros).
GTR8000
NY/NJ Database Guy
BEE00
It depends on whether the system is "Control Channel Only".
You should be ok.
All P25 systems are "Control Channel Only", and that hasn't been a setting with Uniden scanners since the XT series; they are all inherently CC-Only now.
dwh367
Thanks everyone. Since this is a brand new system, still in the testing phase, I wanted to make sure I didn't miss anything as it's my understanding that traffic is still sporadic at the moment.
