Yes I'm backed up 100% by my job but obviously some people
Are just ignorant . I just want to learn how to program the radio to transmit so when I buy a better one I can do it on my own , not pay someone . I just need the steps on how to do it , I don't care about it needing a sticker of part 90 w.e that means I'm good I won't get in trouble for carrying it , I carry a gun all the time , radio is just in my Car .
OK, so you're determined, I see, so I'll bite.
First, to program your radio, you'll need programming software. There is the manufacturers software (which I like) and then there is CHIRP. Both are available for free online. Get both, and play around with them, you'll find that the Manufacturers software is designed just like most commercial radio software, whereas CHIRP was designed with Amateur Radio in mind (+ and - offsets rather than direct input, etc.).
Next, you are going to need to find out what kind of system your are trying to program into your CCR (Cheap Chinese Radio). You'll need to know if the system is VHF, or UHF. If the system is 800mhz, return the radio, it will not work for what you want it to. Also, if the system is trunked, Digital,encrypted or any combination of those, the last sentence also applies.
Next, you'll need to know if the system is simplex, or on a repeater (assuming you got past the last step, ie. not trunked, 800mhz, encrypted, digital or any of those combinations). If it's simplex, you need to know the transmit and receive frequency. you might also need to know a CTCSS or DCS tone. This is a code in the radio that unlocks the squelch in your radio as well as the radios you want to talk to.
Now, say the system is on a repeater, this is slightly different from simplex. This means that the radio transmits on one frequency and receives on another frequency in a method called "semi-duplex". To program this kind of system, you'll need the TX /RX freq. and associated CTCSS or DCS tones.
once you know all this information, you enter it into the radio via the software, and upload that code plug to the radio, and if you did everything right, it will work. But you have to do the leg work to find out all the right information needed to program the radio. None of us can give you that information, since most likely none of us know who you work for, or what those frequencies and tones are.
Now remember, if after you have figured all this out, and successfully program the radio, and you indeed do not have permission to transmit on a public safety radio system, you might end up with a CO telling you when to eat, shower, go to the yard and when to get in your cell. ( In other words, you can go to jail for illegal use of a public safety radio system without permission)
YMMV, only you can be responsible for your own radio use. Good Luck!
