Baofeng BF-888 Programming thru Chirp to Match CLS1110
Tater218
I was given a Baofeng BF-888s to try out and I'm having trouble getting it to work with the CLS1110's we have at work programmed to 464.550 which is one of the pre-programmed freqs that comes stock on the CLS1110's. I have installed Chirp's latest build (as of today) and I have a genuine Baofeng USB cable and no problems downloading from or uploading to the 888... I just cant the correct frequency tone and code settings (I guess).
Can anyone help me understand how to program the BF-888s to operate in conjunction with the CLS1110's?
Our CLS Settings:
CLS1110
UHF
464.550
12.5 bandwidth
Interference Eliminator Code 1 = 67.0hz
KevinC
Other
Super Moderator
Home
No help, but I do commend you for starting a new thread as opposed to hijacking an existing one. That is rare these days. :D
Tater218
Thanks for noticing... I hate it when mine get hijacked, so I try and treat everyone else the same.
I did a search on here for over 3 hours and just couldn't find the right solution yet.
KC9HI
Our CLS Settings:
CLS1110
UHF
464.550
12.5 bandwidth
Review these pages: CHIRP Software Guide - Miklor
Jim KC9HI
jk77
Ohio
When you say that you're "having trouble getting it to work with the CLS1110's we have at work" what precisely do you mean by that?
Tater218
What I mean is I have been able to get the 888's to receive from the CLS1110's, but I CANNOT get the CLS1110's to receive from the 888's.
baltimorecs
Baltimore, MD
Thanks. From what I read I assumed that chirp would be easier. I will give it a try as well.
No, for what you need the Baofeng software is much easier. It is acutually the BF-480 software that is used for the BF-888S. This is all you should have to do program the frequency:
Tater218
A picture...now that's what I really needed. Thanks a bunch. I'll try that.
KC9HI
Our CLS Settings:
CLS1110
UHF
464.550
12.5 bandwidth
Click View in the menu bar and enable "Hide Unused Fields"
Loc = 464.55000
Tone Mode = Tone
Tone = 67.0
Duplex = (None)
Mode = NFM
Jim KC9HI
Tater218
No, for what you need the Baofeng software is much easier. It is actually the BF-480 software that is used for the BF-888S. This is all you should have to do program the frequency:
I tried that software and could not get it to read or write to the radio.
Tater218
Thank you to everyone that helped me with this problem.
I was able to get them working in tandem with the CLS1110's using the following specs.
If anyone can suggest any tweaks that I should perform to these... or if you see anything drastically incorrect or non-FCC friendly, please let me know.
KC9HI
Initially the BF-888s used the BF-480 software. But Baofeng eventually released a programming software specifically for the BF-888s. It is available on the Miklor website.
Jim KC9HI
KC9HI
Your Yellow Dot itinerant channels (1 and 2) should be NFM (narrowband) like the rest.
Jim KC9HI
