Baofeng bf-f8
redneckcellphone
southern comifornia
Been using the baofeng bf-f8 for a few days now at work and besides for the obvious dead spots where I can't hear anyone or have anyone hear me do to not having a repeater the radio was working great. Just now I was using it and I could see someone was transmitting ie my boss the speaker had no sound. Shortly after the radio worked and I heard someone else ask me if I copied.
I don't have another antenna to use right now to test it until I get home so other than testing that is there something else I can do to see why it's not working.
connor - wqnd300
WA0CBW
Shawnee Kansas (Kansas City)
If your boss was talking on a repeater and you are close enough to him his transmitter might be de-sensing your receiver causing you NOT to hear him.
BB
KD8DVR
Elitist Ham
Columbus, Ohio
Or, the boss was simply on another channel. It is possible supervisors use a different channel when they want to only communicate with other supervisors.
chuck_e7
Grayson, GA.
Maybe you guys have CCTSS decode on your radios, and he used a different code!
fieldho
Monticello, Mississippi
When you set up the icom did you do it or was it issued to you. I like the CCTSS code answer. Just maybe, the icom was already programed with a code that you were unaware of and didn't transfer it to your other radio. I believe the F8+ has a code scanning feature that only works while there is a transmission being received, that will identify the correct code if there is one. Tell me about the BaoFeng F8+. Do you like the reversed LCD screen, is it readable? Sorry, is that the BF-F8 or the BF-F8+? The different models have my head spinning trying to keep them straight. I think I'm going to pick up an F8+. I liked the the good looks of the GT-3 (same internal parts) but decided to go with the BF+ because of the compatibility with the old Uv5 batteries. 73 good luck.
Dave
princo
Does the radio have a squelch knob or is it set in the menu? If it's in the menu, I'd try fiddling with it a little.
awasser1
Apache Jct, AZ
if the other party is too close these receivers tend to overload and you get no audio. i find that at work when others are really close i receive nothing.
taboudarajr
Santa Rosa CA
Alert Tones
Does anyone know if the BF-F8+ will accept DTMF alert tones (similar to Fire Pager tones)? The literature is obviously woefully lacking in data like this...
Thanks...
jonwienke
More Info Coming Soon!
VA
It will play them as audio, but isn't going to do anything else with them. You can send them with the keypad while the mic is keyed.
