Baofeng Baofeng DM-1701, how to add a vfo channel manually
PickyBiker
I can now program my ne DM-1701 with CPS, but I don't see how to add a vfo channel to the list manually. The manual doesn't seem to cover that or I missed it.
Example: Without using CPS, how would I add 162.475 to the channel list?
PickyBiker
I used that frequency as an example, I guess that was a bad decision.
If I am away from the computer, am I to understand that there is no way to add a frequency to the list? That sounds hard to believe.
Larry-G
Haven’t powered mine on in over a year but I’m sure I programmed mine via the front panel back then. A quick google search also says it can be front panel programmed. Don’t want to break any forum rules by linking so Google baofeng dm-1701 front panel programming
