Baofeng DM-5R Plus Squelch Question
rgchristy
Delco, PA
I'm having the Baofeng problem where the squelch opens about every 20 seconds, regardless of whether a DMR, analog CSQ or analog with CTCSS or DTS frequency is programmed in the channel. It does it on all channels.
I know that the squelch settings (0-9) are adjustable using CHIRP for the UV-5R models, but since the DM-5R and/or Plus are not on CHIRP yet, and the CPS-5R does not have that capability, does anyone know how to adjust the squelch settings?
Thanks,
Rich C
jonwienke
More Info Coming Soon!
VA
Squelch is a menu setting in all the Baofeng models I own, but I don't own a DM-5R Plus.
If squelch is opening on an analog channel with a DCS code programmed, changing squelch level will not help. Squelch should only open when the programmed DCS code is detected. That is unlikely to happen with random interference.
nd5y
Wichita Falls, TX
If it does it with tone decode enabled then it isn't a squelch problem. It sounds to me like the radio is defective.
rgchristy
Delco, PA
Sorry it took so long, but I finally had the chance to look for what I was talking about. I found it on the Miklor site. Here's the link:
UV5R/UV82 Squelch Levels - Miklor
The problem that I am having is that CHIRP has not been developed for the DM-5R, so I can't access these settings (please see the images). So here are my two questions:
1. Does anyone else that has a DM-5R have this problem?
2. Since I can't use CHIRP to program the radio, is there any other way to access these settings?
Thanks again,
Rich
rgchristy
Delco, PA
Another thing came to mind. It's as though someone is pressing the MONItor button to open the squelch.
WPXS472
Heflin, AL
My DM5-R plus does it when in CTCSS mode. I call it "spitting" because that is sort of what it sounds like. It may also do it in carrier squelch mode too, but I don't seem to notice it as much. I haven't used DCS or DMR enough to know. I find it annoying. I believe it is an inherent problem with the design. If someone does come up with a fix, I'd love to know.
rgchristy
Delco, PA
According to the link that I posted above, the problem can be fixed by adjusting the squelch settings. Unfortunately, the only CPS in which you make the adjustments, is CHIRP. CHIRP does not currently support the DM-5R. The Baofeng CPS will not allow you to make the adjustments.
