Baofeng Baofeng dual watch/TX lock problem
AB6CJ
Lock/unlock TX during dual watch does not work
For my Baofeng F8HP, I have a 440 freq on top (Band A) & a 144 freq on bottom (Band B). The active band (arrow next to it) is on top (Band A). With Dual Watch #7 on, I can hear both bands.
With TX lock #34 off, when I receive on Band B, the TX is supposed to be on Band B but instead the TX is on Band A (active band). With TX lock #34 set to Band B, the TX is supposed to be on Band B but instead the TX is on Band A (active band). How can I get this to work? Thanks.
nd5y
Wichita Falls, TX
I think I read several years ago that Menu 34 TDR-AB doesn't work the same way on different firmware versions. If the OFF/A/B settings don't do what you want then there is no way to fix it.
If you need complete control over which band you want to transmit on then you should have bought one of the UV-82 type radios that have two PTT switches.
