Baofeng on Motorola Minitor Tone Out
rogersjoey6
Greenfield, Indiana
Quick Question
I am a recently new member of an all volunteer department in Shelby County Indiana and have been issued a minitor 6 for receiving calls. I live a little out of district and far from the county dispatch so the pager does not pick up as well as my Baofeng UV-5R or my UV-82. In fact if I key up on the county frequency on either baofeng the pager picks it up just fine, but on my "Department only" Channel on my pager it does not pick it up so I know it has a tone to it. I have been just using my baofengs to pick up the calls and waking up whenever anyone in the county gets toned (which is getting old after a month now) and my assistant chief said my chief programs our pagers and should give me the tone out code.
My minitor 6 ranges 143-174mhz...
chrishoerner
KC3KSJ
Frederica, Delaware
You should NOT be keying your radio on a Public Safety Frequency!
You should program the Baofeng with a computer so that you can disable the transmitter on those channels. The Baofeng will not go off with your station tone off tones. As for your company channel if you know the frequency you do not necessarily need to PL tone (PRIVATE LINE) to monitor it.
Google the difference between tone out and pl tones.
toastycookies
the far east
Quick Question
What exactly is the question?
Since this was brought up, you can disable tx in chirp by choosing off. Then you can also go to settings tab on left in chirp and uncheck vhf transmit. But the baofengs to my.knowledge do not do quick call or quick call II.
lmrtek
the uv5r has a HORRIBLE receiver
it takes FAR more than sensitivity to hear reliably
any transmitter within a couple miles will desense it into the noise
I certainly wouldn't risk lives depending on it
p
DJ11DLN
Mudhole, IN
I believe that the OP was asking about using his Baofeng CCR's for fire tone-out. The answer to that is that neither model listed supports 2-tone paging. There are radios out there, and scanners too, that do support 2-tone and which will offer an improvement over the performance of a pager. Likewise, as another poster has mentioned the Motorola pager referenced does have a dock available that has an external antenna which will improve performance. Look around on eBay, Amazon, etc.
As far as it being illegal for the OP to transmit via his CCR radios on the county fire dispatch...read his original post. He is an accredited Firefighter, albeit a new one. If the radios in question are Part 90 certified, then he most likely does have the legal right to use them on his authorized frequency.
cobraultra
Pittsburgh, PA
Here is what you can do with the UV-5R.... Get a 2.5mm male to 3.5mm female adapter. then use a computer with TwoToneDetect on it. Connect 5R with regular male to male 3.5mm headphone cable. configure TTD with your departments tones and you are ready to go. You can set the computer to alert with a sound... as well as only open the speaker when tones are detected. as well as send yourself a MMS message or email to your phone.
robertmac
Hope his vehicle is big enough to have this set up mobile.
Just a thought, have you considered buying a surplus used ht1000 dn model, or ht1250 for your paging needs? While the ht1000 is old it will do quick call 2. Since your just needing the device for paging, a 2 channel or 16 channel ht1000 would suit your need. Channel 1 being page toned with your pl and dpl with qcII, ch 2 csq with qcII, ch 3 monitor of the raw frequency pl or csq. Just a thought. Just make sure it's a DN model of the ht1000. They are pretty cheap these days and are pretty good old radios. You could go the route of ht1250 or something but the cost would be higher. For what you want a ht1000 very basic, cheap would do what you need.
rogersjoey6
Greenfield, Indiana
This is what I have been looking for! A radio that supports the 2 tone out quick call like the minitor and doesnt break the wallet.
rogersjoey6
Greenfield, Indiana
Thank you all for the responses, I think from what I have read here I can not get the 2 tone out feature on my baofengs. So now I am going to find a radio that supports that, with a good antenna.
Hop763
Ky
Correct, you can get an amp charger with the antenna hooked to the back, or hook an external antenna outside to the unit, by using the BNC fitting on the back.
krokus
Southeastern Michigan
The Kenwood TK-290 is another option.
Sent via Tapatalk
MotoTRK
I have motorola CDM's available that LOVE being used as paging receivers. Sell a bunch to fire departments that need station alerting from a base mobile unit.
