baofeng program
jasonk111281
connecticut
I downloaded the program for the uv-5r when i go to open it all it does is flash on the screen like it keeps trying to open but wont stay open has anyone else had this problem with it
ermin
Jacksonville Florida
Yes. Could not get it to work with Windows 7. Get CHIRP. Works great for over a year now.
73
Ermin
spcingersoll
miklor.com ought to have all the guidance you seek for the UV-5R. I've had great success with the baofeng software.
Sent from my iPhone using Tapatalk - now Free
n6dlh
Hampton, VA
Do your self a favor and use Chirp. Much better than the BF software. You can also import from other software.
Dave
K3NXU
Shrewsbury, PA
The reason for the flashing is the software searching for the Cables Com port
The flashing stops when the programming cable is plugged in.
Drivers is normally the biggest issues with the generic programming cables.
Win7/8 drivers cannot be newer than Prolific 3.2.0.0 (XP, Prolific 2.0.2.1)
If you run into any issues, the latest Software and Proper Drivers can be found at http://www.miklor.com/uv5r
Once you get it up and running, you'll love it.
Hope this helps...
John K3NXU
