Baofeng Baofeng Programming Help
kd4bas
Monitoring, Hanging Out, & --mn-@v@-mn-- you.
Morganfield, (Union Co) KY
I recently purchased a Baofeng UV-82 and while trying to program in a repeater frequency via chirp and using a DTCS of 712, I can not get the radio to transmit the tone correctly to key the repeater. I have tried the "NN", "RN", "NR", and "RR" setting for the DTCS code all with no luck. I have checked with the operator and he says this is the proper code and doesn't understand why I can't key the repeater.
Does anybody have any suggestions.
FYI, I have also tried this on my Baofeng UV-16 Pro, same issue. Regular (Motorolas, Icoms, & Kenwoods) radios seem to be able to host of other Baofeng radios.
MedicMike153
FN31lf
I am fairly certain it should be NN. That's what I have on my UV-82C for one of my services. Maybe check the offset and the Tone Mode is correct.
kd4bas
Sorry for the delay in replying. Found out that radio repair has made a change at the receiver site and Baofengs are no longer able to access the repeater site. Not sure what the change is/was, but that is their business, not mine.
