BAOFENG to MAGONE Transmission Issue
catford
I got a baofeng UV-5RA radio this morning for christmas, I previously own a Motorola MAG ONE,
With the new UV I got today I can hear transmission from the motorola however when I go to transmit from the baofeng the motorola light comes on as if its picking up the talking however just silence no voice or speaking.
Has anyone else seen this problem? ? ?
I have included a picture of my motorola settings any help would be great!!!
RBMTS
It appears that your Motorola is setup to monitor with TPL or DPL (coded squelch) and I bet your Baofeng is transmitting without a tone. Depending on which MURS frequency you plan to use in your illustration, you'll need to set the Xmit DCS code on the Baofeng (which is what is referred to as DPL on your sheet) to the same code as the Motorola. Then you should be fine.
