BrettL
I don't have the software for this unit so I manual program it. It's not really all that hard to manually program it and I've had it for 3 weeks now and got really accustom to the settings.
I go to frequency mode and program the frequency of the repeater, then the 600Hz offset + or - and store it to a channel. I have squelch at 0. Battery save set 0. Vox off, wide band, BCL off. T- CTCS to whatever the charts say.
The thing has been acting weird. At first I scanned 90 frequencies for 2 weeks just to listen. Everything was fine. THEN I GOT MY LISCENSE!
I re-programmed it so I could transmit and get my first contact. It worked. Then I added more frequencies using local repeater charts. It would not talk on channel mode and in frequency mode it would not even key up. So I switched from A mode to B mode and programmed the frequencies to a channel and it talked fine in frequency mode or channel mode.
I reset the unit to see if I could get A mode to work correctly with same settings and it worked fine. The next day I had no receive and people could hear me. Then A mode stopped working again. Would not key up.
Some of the settings change after I store them. For example offset 000.600 changes to 000.000 for no reason. Sometimes the C-CTCS resets from 131.8HZ to off . This thing is so unstable. As of now I have one frequency in it stored in A and B mode. It will Key and Receive in both modes also channel and frequency mode.
What seems to be the problem?
