Baofeng BAOFENG UV-5R Im NEW
fullerton
Im trying to download the frequencies in my area ! Im using CHIRP but its not letting me do it com Radio Reference It keeps saying (Not Responding) when I try to log in into to my account! Yes Im a paid member of Radio Reference! Thank you I included an image BAFNG.jpg
n0xvz
San Angelo, TX
That looks like your computer might be bogging down with the software, not the RR database. What operating system are you using? How much RAM do you have? What other processes do you have running in the background?
When you attempt to use the Radio Reference database there is two options, Import From Data Source and Query Data Source, I can not get the query option to work, however the import option does work. Did you try both?
fullerton
Thank you for your reply ! I will check
Thank you for your reply ! I will check when I login into my computer
As for operating system it’s windows I will get back to you on the other question thanks
ko6jw_2
Santa Ynez, CA
If you are in Fullerton CA there will be little that you will be able to program/receive. Orange County uses an 800MHz trunked digital (P25) system. Your radio can neither receive 800MHz nor follow a trunked system nor decode P25. It is almost useless in that area.
Most public safety systems in OC are encrypted anyway.
fullerton
Thank you for your reply! Yea i noticed I'm trying to get as much as I am able to ! unfortunately a lot of it is encrypted
fullerton
So this is what it reads 4.00 GB (3.42 GB usable)
fullerton
Its from Query Data Source ! I don't see an Import From Data Source option ! What are you using to downloads the frequencies ??
It will not let you do it unless there is a img file open, open a file or download from radio, then it will allow you to use the import, this opens a new window for you to choose from.
TomLine
Hamilton, Ohio
A RTL-SDR with SDR# (sdr-sharp) would show your local traffic pretty well.
I had trouble downloading from radioreference into SDRTRUNK as I was using my email address instead of my actual user id.
I bet you can hear FRS and MURS, and 2 meter repeaters in your area just driving around. Chirp is great, but the syntax takes some time to digest.
