Baofeng UV-5R UHF Problem
wv8mat
Letart, WV
I bought one of these dual banders basically just to play with..... I went to put our UHF repeater in and it gets nothing but noise. Does anyone else have problems with that on UHF. The Frequency is 442.000+ / tx audio is fine, no noise but the rx audio is so bad you can't hear people talking at all.
RBMTS
It is internally generated interference - a "birdie" if you will. I just tried it on mine and I receive a carrier without an antenna. Looks like you are SOL for that particular frequency. Sorry to hear that.
BTW - my Cisco IP phone generates an IF signal that causes interference for me on 442.300 that is not present on other radios. Oh well.
N5TWB
Sand Springs OK
Same here on the 442.00 "birdie" -- particularly irritating because that is my closest input to a regional link system.
wv8mat
Letart, WV
well crap. thank goodness I have my other gear to fall back on. Oh well I bought it to tinker with and now that other folks have tried it I know its not a bad radio.
Thanks for the info.
K4APR
Chesapeake, VA.
That's a shame. I'll have to check my UV-3R for the same birdie. I actually use my 3R 99% for UHF, but our local repeater is 444.880+ and I haven't seen a problem there. In fact, it's one of my best sounding radios on UHF. At least, that is my opinion on this Chicom "junk" radio :D
nbccsa
No noise on mine w/ RH-771 antenna. Firmware 251. I hear static with no antenna, but not with it, so why would it matter?
alprice
Jacksonville, FL
UHF Problem
2 possible solutions....
If your using the rubber dummy load that comes w/the radio change it the NA-771 and 701 are prime antenna's.....
If the repeater uses a tone, program the radio to use the tone/squelch option. Not the tone alone but the tone/squelch. Thats utilizing the input and output tone features.
Hope you get it worked out
73
Al/N4GOD
wv8mat
Letart, WV
even with a rx tone it still sounds bad and you can't hear what the other person is saying. I tried a few different antennas and still the same little birdie
