baofeng uv-5r
rtm3702
Lehighton,pa
can the uv-5r be programmed to the dcnr narrow band frequencies in it,if so im having problems i can recieve but not transmit can anyone help me with this
m-gerty
Miiddle TN
What do you mean, you can't transmit? Can another radio not hear yours? Have you double checked the transmit frequency? The software doesn't work very well and I've had numbers change in the program for no reason. Also check pl tone, if any..
RohnsRadio
Duplin County, NC
so this radio is type accepeted ,or approved as the case may be , for part 90 under narrow band? i knew it would do the present system.
if so i may have to pick up one . coast guard aux has some channels we can use but it must be narrow band.
m-gerty
Miiddle TN
PM from the OP:
i have 2 radios on the forestry channels and i cant hear either one when i key up but i can hear the victor units but cant transmit to them
I don't understand? You can't hear when you key up? What are victor units?
