baofeng uv-5r
magana1216
Calumet City , IL
im currently trying to enter my local public safety frequencies on my baofeng uv-5r and it keeps telling me "error...out of range" message like that. Can anyone help me out?
magana1216
Calumet City , IL
how am I able to check for that?
Are the frequencies within these specs?
UV-5R SPECIFICATIONS
Frequency range:
[RX] 136 - 174MHz, 400 - 520MHz, 68-108MHz (FM Broadcast)
jonwienke
More Info Coming Soon!
VA
It's out of the range of frequencies the radio can accept, just like the error message said.
Also, entering police frequencies in a transmit-capable radio is a really bad idea--if you transmit on those frequencies, even accidentally, you can get into serious legal trouble. And the UV-5R is an analog-only radio that can't decode the digital P25 signal used by most public safety agencies. It also cannot track the trunked systems most often associated with P25 digital.
Get a scanner, and you'll be able to hear the digital signals and there is no possibility of accidentally transmitting and getting into trouble.
jonwienke
VA
Usually the agency will give you a radio if you are an employee. Have you inquired about that?
magana1216
Calumet City , IL
I have. Buh our department as emergency management is low funded and only have a single radio for duty use. I had asked a supervisor about getting a scanner myself. Just to simply monitor the police traffic since i am on call 24/7 but i might just use my baofeng for recreational use at airsoft events. And purchase a scanner another time.
jonwienke
VA
A scanner is probably your best bet. If you indicate your agency, we could advise you regarding which model you would need to hear anything.
jonwienke
VA
I see two frequencies listed for Calumet City ESDA:
856.21250 and 155.055
You're going to need a 325P2, 436HP, or SDS100 to be able to scan the 800MHz frequency. If you want to receive the Starcom trunked system, the SDS100 is your best bet, because Cook County uses simulcast, which the other units have difficulty receiving. But it is the most expensive--$650 new.
magana1216
Calumet City , IL
Yea. We operate our shift with police and if we get called for an emergecy operation we will use the 155.055 to communicate with our co workers. But generally is there anything on amazon?
jonwienke
VA
All three of the scanners I mentioned are available on Amazon. Any radio that can transmit on 800MHz is going to cost even more, especially if you want dual-band 800MHz + VHF.
If transmitting is a requirement, you may be able to find a used Motorola for slightly less than a scanner, but programming software can cost more than the radio, and the complexities of programming them have many pitfalls. Before considering that route, find someone who knows what they are doing and has access to the programming software. Maybe post in the Motorola forum noting your agency and frequencies needed.
JohnnyGent
Banned
Banned
Chicago Burbs, IL
So enter the 155.055Mhz in your baofeng if you have permission to transmit, your should be fine. If not set for receive only. That will do both on that VHF frequency.
Scan On!
