This is interesting:
Just to keep the record straight, radios that are type-accepted for licensed GMRS use are permitted to have removable antennas. It's the "License-by-Rule" FRS radios that are required to have lower TX power and fixed antennas.I see they note "antenna is fixed" and further state that it is illegal to sell a GMRS with a detachable antenna <snip>
Leave it to Baofeng to screw something upJust to keep the record straight, radios that are type-accepted for licensed GMRS use are permitted to have removable antennas. It's the "License-by-Rule" FRS radios that are required to have lower TX power and fixed antennas.
Are they really type accepted? She says so. Needs more research I think.
More polishing going on...GMRS version of the UV-82 certified.
B-Tech does make, as we know, legal GMRS radios. Legal because they cannot transmit other than on GMRS frequencies. No FRS.
en.wikipedia.org
Actually when you are using FRS equipment, the limit is half a watt for multiple channels.Yep. But at a half watt, appropriate use wouldn't cause any disruptions to anyone, therefore it would be next to impossible to catch someone.
You're talking about a band that allows up to 50 watts, and Midland makes a 40-watt mobile. I highly doubt that keying up on a half-watt walkie talkie with a better antenna is going to alert anyone of anything to get you a knock on your door.
It's not like a CB guy who decides to run 300 watts of output power and causes harmful interference.
I've been up and down the FCC's records of enforcement action, and there's never been a single individual cited for GMRS misuse. A manufacturer, however, did receive some FCC correspondence.
Leave it to Baofeng to screw something up![]()
