Baofeng UV-82 and Chirp
rogersjoey6
Greenfield, Indiana
For all those who know about Baofeng and Chirp and compatibility it can be a trick to figure out. I have programmed a UV-5R with it. But my question is can a UV-82 be programmed off of it? My 5 buck cable can not read the UV-82 but works fine on the UV-5R I have read that a 20 dollar cable works better than the one I have. But just wanted to make sure it would work before dropping 20 bucks.
n9mxq
Belvidere IL
I have the 2/220 version and chirp works fine, as does the cable for my UV-5r. Just make sure the plug is in all the way.
You get what you pay for. The Baofeng radios seem picky on their cable, model specific. If you know the $20 works then buy it, those cheaper cables are hit and miss and save yourself time and money just buy the $20 if you know it will work.
Here is a good example. I lost the USB programming cable for my Wouxun KG-UPD1P and turned to e-bay for a new one. First one was DOA, sent it back for a refund. Found a second one but the driver disk did not have any drivers but it did have Baofeng programming software to program the Wouxun which I only program it with Chirp or the official Wouxon software. Found drivers online for the USB cable but these were not correct and even got the BSOD in Win8.1. While exploring the driver disk, there was a Motorola folder containing some older RSS for like the GP300, etc. The radios and RSS are long done but the RSS is still copyrighted by Motorola and should not have been on that disk. I was so ticked off that the seller refunded me without sending the cable back.
Radio City, a real live amateur radio store (known by fellow hams as "the candy store") located in a NE suburb of the metro are is a dealer for Wouxun radios and had the official programming cable for just a few more dollars then the ones on e-bay. With all of that buying and returning and time lost, saving a whole $5.00 was useless. I wish I knew this before trying to save a few lousy bucks buying on he web. The locally purchased cable works like a charm.
n9mxq
Belvidere IL
2/220 UV-82. Chirp programs it just dandy
Sent from my SM-G930V using Tapatalk
mm
oregon
I am using chirp version 20150118 and a 220/2 UV-82X which works fine.
There is a special method at Miklor which describes loading the proper usb driver for the UV-82/X under chirp, if your usb driver is not correct then the radio will not communicate with the software.
I followed this procedure and then I turned off windows Automatic updates because prior to this windows Auto update reset my usb drivers to a default driver which stopped chirp from communicating with my radio.
Cables & Drivers - Prolific & FTDI
UV82 - Miklor
