Baofeng Baofeng Uv-82c and Chirp
jeffycc
Nashua NH
Does the CHIRP software allow you to add a tx frequency or is this where the Duplex +/- and Offset is for?
Thanks!
nd5y
Wichita Falls, TX
On the radio, not programming software, the +/- shift direction (Menu 25) and offset (Menu 26) only work in VFO (frequency) mode.
You can't store that to a memory channel. You have to program the TX and RX frequencies separately.
CHIRP works both ways for programming memory channels.
The Duplex column is the shift direction and the Offset column is the offset.
You can also set the Duplex column to split and enter the actual tx frequency in the Offset column.
See MemoryEditorColumns - CHIRP
scanmanmi
Central Michigan
Chirp did not work on 2/3 of my radios so I am using the factory program fine. Is there any advantage to Chirp?
