Recently purchased a Baofeng UV-82HP dual band HT. I own an older Yaesu 530 + 50R. Both are the old style manual programing only, so I had a head start on the Baofeng. Here are some tips I discovered along the way with manual programming the UV-82HP. There are several youtube videos on how to manually program but I created my own easy way.
Here are the steps:
1. Make sure you are in frequency mode n VFO A
2. Turn off Dual Watch #7
3. Program RECEIVE frequency into VFO A
4. Code Squelch # 13 if needed
5. Freq Step # 01 (you can set default for 2M + 70cm 440 bands.
6. Simplex or Freq Step (repeater) # 25 - Simplex - or +
7. Output Power Setting #02 Low 1w, Med 5w, High 7w 2meter or 6w 440 band
8. Save to memory channel #27 then select channel number. If you see a CC before a channel number, that one is taken. Channels with only 3 digit number (no CC) are available. If you want to OVERWRITE an existing channel, go to Menu #28 and delete that channel. I keep the voice command turned ON along with key press beeps for confirmation. The voice is helpful with voice confirmations as well. Ok, now go back to menu #27 and save to that channel again (if you removed one)
9. Next step, with all setting correct, key the radio with your HAM id for a signal check. If you receive a confirmation back, all is set to save to memory
10. This is the important step if programming a freq with an offset. For example, I programmed 147.100 as the receive, with a + offset of .06. Including a PL Tone of 100.0, all worked and Ham reported loud and clear. So I saved it to a memory channel. Then I turned off radio, held menu button and turned back on to to go Channel mode. Keyed the new freq channel but did not work. This is where the IMPORTANT manual program step WAS MISSED!. Go back to VFO A where your original channel and settings are saved. Re-enter the TRANSMIT frequency and verify the same offsets, power, PL tones are still the same. Now SAVE this to the SAME channel number as you previously did. Do not delete using #28. This radio has 2 steps in saving a separate trans/receive in order to work in Channel mode.
I made a cheat sheet with the steps and menu numbers on an index card, stuck it in my wallet for when on the road. It is attached to this post in PDF and Text formats. You can save, print and keep it handy.
Ran into a small problem saving one memory channel though!
Was in VFO A, on NOAA 162.400 receive. Radio would not write to a memory channel! BaofengTech support said the radio saves any receive freq to memory. Mine would not and I even did a factory reset to defaults. Would save 162.395 + 162.405 fine, 162.400 would not! BaofengTech support suggested removal of antenna first on strong signals. I removed antenna and 162.400 saved to memory!! Not in the manual but if programming in VFO A and everything works on checks, REMOVE the antenna if the channel is broadcasting, or it might not save to memory. This is another reason I leave the voice command turned on. When I hear a voice saying what steps I am taking, that helps in knowing! Also when it writes to a memory channel, the voice will indicate success! Hope this helps
Here are the steps:
