baofeng uv-8d
countryoby1365
Im looking for programing software for the uv-8d can any one point me in the right direction.
Nicholas440
Mentor Ohio
I have not heard of a UV 8D by Baofeng, but I assume you can locate if with a Google search. The Chirp software might work on it too I am not sure.
xxdanielt3
PA
Uv-8D? I have never heard of that radio. They must have just released it.
SHULER
monetta, sc
Baofeng UV-8D
8 watt 400-480 MHz UHF radio
programming cable for uv5R seems to work
no templates in Chirp as of a few days ago....
seems to be similar to uv-82. I wont get a radio without a display again.... cant be programmed without software and that software does not exist anywhere....
tried baofeng site to see if there was something there but nothing Vaporware....
Will have to be patient and wait to be able to use these.
have a good feel in hand as are full size not the mini uv5r size.
2800 maH battery bl-8 7.4V
would be a good form factor for uv-5r update. add a multiline display - maybe 4 lines possible
be patient...
jaspence
Michigan
UV-8D
8 watts seems a little suspicious, especially in the 400 band with a 7.4 volt battery. Even the professional UHF radios are kept around 4 watts due to the radiation and antenna position when transmitting.
baltimorecs
Baltimore, MD
I have a TYT TC8000 that is supposed to be 10 watts but it shows 6.5 on hi power and 5 on low. I am willing to bet it is similar with the Baofeng.
