Full disclosure: I am a non-paid spokesperson for Visbro Technologies, the exclusive distributor of the UV-8HX.
The 2015 Baofeng UV-8HX is the 3rd and final generation as well as the high power version of the UV-5R
It can transmit on 3 power levels, 1w/4w/8w.
The manufacturer states the maximum range being 10km (6.2mi) but I was able to hit a 70cm repeater 11.3 miles away, KU1Q in Goshen on 1 watt power using the stock rubber ducky antenna from inside my house. Max power on 2m is 8w while max power on 70cm is 7w.
the UV-8HX has many of the same features as the UV-5R and can use the same Li-on batteries (BL-5 and BL-5L), same antennas and other accessories as the UV-5R.
It has updated firmware and a custom RF power MOSFET. The menu has some (better) differences compared to the UV-5R+ and reception sounds cleaner as well.
The UV-8HX is field programmable but you can program this radio using CHIRP also, provided you have the programming cable. The battery arrived about 85% charged and the HT was ready to go right out of the box.
This is another great HT from Baofeng and costs just around $55.00. I highly recommend this radio.
If you would like more info or to see this radio in action, check out my YouTube channel.
