defender2086
Is there a way to improve the range of the Baofeng UV-9G GMRS without a repeater? I did a side by side range test in the city with a pair for well known Midland Two Way GMRS handheld radios and a pair of UV-9G’s. I understand the range is extremely limited in urban areas. However, I had hoped the UV-9G would have performed better than the Midlands. I was able to get up to a 1 1/2 transmission with the Midlands. However, using the same test I maybe only got an 1/8 of a mile with the Baofeng. The power setting is set to high on both. I would appreciate any advice. Thank you.
