Baofeng Baofeng UV17R-Plus
pdtek
I just spent the big bucks and got a UV17R-Plus. Trying to program some aircraft frequencies into it using Chirp (first experience). Chirp does not have the UV17R-Plus as a programmable model, only the Pro version. It will not allow me to to enter air band frequencies. Any input on how to fix this on the cheapest radio that I ever purchased.....
Thanks for any help.
a727469
Maine
I have the 17r+ but have not used for air. You might want to manually program an air freq, upload to chirp and see what happens. I used the 17pro.
PRMII
Central Texas
I can enter a freq for the local airport manually into the VFO, and hear aircraft, but I've not been able to program any of the aircraft frequencies and save them to scan.
I used the most current version of Chirp, I've used the Baofeng software, and have tried to do it manually from the keypad.
No Joy here.
I'm searching various forums online to try to find an answer. If anyone with the UV-17 R Plus has accomplished, Id appreciate the Intel.
PRMII
Central Texas
I'll download the latest version later today, and try again. If not, I'll try the 5RM.
I appreciate the help
I'll also come back with my results for others to see/use.
a727469
Maine
For receive, quite good, have not tried transmit yet Somewhat long squelch tail. Not sure about junk design since I think it is quite an attractive and sensitive radio. For the price a very nice radio and it has acceptable air band receive! I know, it is Chinese, and I would much prefer to buy USA, but I could not find one made here.😟👿
MTS2000des
5B2_BEE00 Czar
I tried one and the one thing I can say is the one I tried had surprisingly CLEAR transmit audio that wasn't muffled and mumbly low like many of these CCRs often suffer from. Otherwise, same piss poor RX performance easily overloaded. But it does have a jazzy color display and all important flashlight!
a727469
Maine
Love the flashlight! 🔦Actually could not care less🥱but I find the receiver excellent, but I live in a fairly low rf environment so no overload here, but obviously could be a big factor in a busy metro area.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
So it 'works great' then?
KQ4SOV
I just used Chirp to program ~50 repeaters into my UV-17R Plus on an HP Windows 11 machine. Smooth as silk. Changed to channel mode and scanned away. I put 'em starting at channel 101 to keep lower numbers free for other use. I downloaded current config from radio following Chirp instructions, saved a backup copy, then downloaded to csv file from Repeaterbook, then copied and pasted in Chirp. Uploaded and no problems. Only wrinkle was choosing the Port in Chirp, but it suggested a Com port to use, so I tried it and no problems... Good Luck!
WX9RLT
Top Dawg
That one place...
Ditto
I had to get the radio, then connect and upload to Chirp.
That way Chirp had the UV-17R Plus file.
Then smooth sailing from there.
I had previous issues, trying to program it.
WITHOUT connecting to Chirp first.
Connect your radio to Chirp first.
Then program it.
