BaoFung UV-B5 How to setup scanning mode
racarl
Fitchburg, Massachusetts
I am a newbie. I bought a UV-B5 for scanning local Emergency channels. I bot a programming cable and used Chirp to program in 18 frequencies. Currently, I have them programmed in and can listen to them one at a time. The Programming Manual is not clear. Can anyone tell me how to manually program the radio to scan channels 1 thru 18 or 1 thru 5.
Thanks,
nd5y
Wichita Falls, TX
Go to View/Columns and make sure all the columns are checked so they are all visible in the Memories tab.
Make sure the Skip column is blank for the channels that you want to scan and for channels you DON'T want to scan, like weather channels, set the Skip column to S.
instructions are at MemoryEditorColumns - CHIRP
