ScottE22
What is a good antenna for monitoring 700-800 MHz P25 digital trunking public safety systems?
Re-read the title.Handheld, mobile, or base?
I use the same base station adapter but the antenna is a 13 inch whip with coil located bottom mid section. Same frequency range but out performed the laird i tried that antenna but 13 inch whip had much more favorable resultsIf you are in Hickory, Catawba county, it doesn't appear that there is simulcast in your area according to the database. If your only interest is listening the the Viper system, you can get a ground plane set-up with simple whip antenna. Here are some ideas.
Ground plane kit.
Laird Technologies MBC800 - $29.95 : The Antenna Farm, Your two way radio source
Antennas.
Laird Technologies QW760 - $9.95 : The Antenna Farm, Your two way radio source
Laird Technologies B7603 - $33.95 : The Antenna Farm, Your two way radio source
These may be the most economical options. You would have to purchase quality coax and some type of mounting pole to mount the ground plane kit to. Maybe others will chime in with better options.
Thanks for the info,my main interest are Catawba county Sheriff's department and Burke county sheriff's department, both on NC VIPER, having issues with multicast dropout,got good signal, and it's not always an issue. Noticed if I lock on a dept channel, many times I end up missing transmissions,sometimes for some time,maybe need to get a SDS100/200...If you are in Hickory, Catawba county, it doesn't appear that there is simulcast in your area according to the database. If your only interest is listening the the Viper system, you can get a ground plane set-up with simple whip antenna. Here are some ideas.
Ground plane kit.
Antennas.
I simply made the whip out of stainless steel wire 18 gauge. And i had an old 800 MHz whip that the threads were bad and modeled it by wrapping the coil part of the antenna wire around a small diameter Phillips screw driver about an inch keeping the coils wound close to one another with out each wrap not touching the other. I mounted the end into an F type female to female connector the total length was 13 inches. The coil starts 2 inches above from where it connects into the F connector.Can you post a link to that antenna? I may use one on my car.
What issues do the SDS100/200 have,out of curiosity?Also,appreciate the suggestions, already had squelch at 2,may try the other suggestions as well....I'm assuming you have a 436 or 536. Make sure you check your squelch setting. You shouldn't need anything above 4. Also, try adjusting the settings for P25 threshold and P25 filter. It can make a little difference. If your budget allows a SDS100/200, then have at it. Just beware of some of the issues those radios have.
Thanks..There have been mentions of cold solder joints making the radios not receive signals. Also, there are some display issues, although I think those may be isolated. If you take a look here, you can read the comments and make a more educated decision.
Uniden Prospective Owners | RadioReference.com Forums
Any pics available?I got a free 800 MHz mobile antenna (5/8 over 1/4 wave) with an NMO base when somebody changed systems. I found a round piece of thin, flat steel in the scrap bin that was around 6" in diameter. Drilled a 3/4" hole in the middle, and installed an NMO mount. Screwed the plate to a piece of aluminum L-channel scrap for a stand-off, and U-bolted it to the mast.
