I'm building an interesting mast this winter, will be neat to see how it works out.
Base will be a 16 foot pressure treated 4x4 sunk 3' into a concrete base, top end will be bolted to the end of the rafters/eaves that overhang there. The mast itself will consist of a 16' 4x4, two 12' 2x4's and one 10' 2x4 on the end, like so:
Code:
--------------2x4------------
===4x4===== --------------2x4----------
There'll be a very slight taper on the 2x4's spacing between one end and the other, obviously. I will cross brace them at a couple locations as well for stiffness.
Overlaps will be 2' so 8' (top) + 10ft (mid) + 14 ft (bottom) gives a total of 32 feet height. Mounted at 1' above ground level on a hinged base gives an even 33. On the end of the 2x4 I am mounting a short piece of mast to stack an Alliance U-110, 6 element 2m/440 yagi and a Diamond F22. In addition I will likely have a discone or 800 antenna on a side mast, just to feed the scanners.
It'll be interesting to work with the material and try to get this thing stiff enough to freestand at that height. My top anchor point is to solid old-growth pine 2x12 rafters at 12 feet above ground level; I intend to tie the ends of 4 of the rafters together with a pressure treated 2x4 + lag bolts and bolt the ground-sunk post's top end to that. The foldover section will be pinned to the ground-sunk post at that height with a big honkin' bolt and nut when it's all in place.
If anybody has any suggestions/number tweaking (besides 'buy a tower'), please mention it!
