base charger problem?
W
W4ZMJ
Guest
Has any one notice problems with the base charger? I have a issue more often than not where if is in the base it comes through the base speaker fine, but sometimes when I cut it off then turn on the next day it acts like it not picking up the pager being in there. it will charge but want put the audio though the base. I have taken it out put it back in it will say charging but audio will come out the pager only. The only solution I've come up with is to program the pager again then it works fine. This might last a few days then next time I cut it on doing it again. Has any one had this issue?
tipster67
Wichita, KS
Yes, I have had it do that to me. No, I don't a good solution. But you ain't alone. I have never had to re-program. I just slip it in a few times till the sound is correct.
kruser
West St Louis County, MO
I use a damp wash cloth and wipe the contacts on the base of my G5 and it works every time, must be a contact issue.
Dennis
I must do similar with my G5 for the G5 to use the external antenna attached to the charger base.
It does seem like a contact problem as cleaning them on the G5 and in the charger base restores normal operation each time I need to do this.
Luckily, it does not happen often.
CFP387
Rowan County, NC
Is it normal for there to be a delay in audio when the G4/5 is in the amplified charger? Mine has always had a one-second or so delay when it's in the cradle.
kruser
Try some Caig R5, applied to both sets of contacts, with a cotton swab.
Using this Caig product is the better fix by far!
When I'm in a hurry, the quick wipe of the contacts does work. I usually just use a dry cloth or even a clean pencil eraser on occasion if I don't have the good stuff handy. Sometimes just a wipe by the fingers takes care of any problems or simply reseating the G5 in the cradle.
One thing I've noticed is cleaning the contacts has always restored any odd problems with the charging cradle. My G5 is also used mainly indoors only in a clean and smoke free environment so contact cleanliness must play an important part.
CFP387, I can't say I've ever noticed any audio delay when in the amplified charger but I don't think I've ever had another radio running so I may not have noticed it.
I'll try and do a comparison in and out of the charger with another radio on the system and see if I can duplicate what you see.
CFP387
Rowan County, NC
CFP387, I can't say I've ever noticed any audio delay when in the amplified charger but I don't think I've ever had another radio running so I may not have noticed it. I'll try and do a comparison in and out of the charger with another radio on the system and see if I can duplicate what you see.
I keep at least two radios going on the same system at all times and I've had the issue since the first day I've used the amplifier charger right out of the box. It may be it's normal operation but I'm still curious as to whether anyone else experiences it.
JD21960
ILL-annoyed
Yes. Mine has that delay. It's very slight. They built that in no doubt for Pager voice buffering and other things to sync up with the PPS. My Pro96 runs the same signal just slightly ahead of the G5 when I have the Pager in my charger/Amp. After a recent update .. the Charger was harder to find the right (spot) for it to work. I now put it IN (squeezing) the belt-clip of course, then pull the top towards me slowly and it finds the right spot.
KI6AOK
San Diego
Anyone notice that while in the amplified charger, the last syllable of a transmission will sometimes be cut off? Doesn't happen out of the charger.
