Base installation question
gdog25
GA
What are some suggestions for getting the coax from the outside to the inside without causing marital troubles or leaving gaping holes in the structure? Thanks.
Grog
Banned
West of Charlotte NC
A window pass-through works for some. It's a piece of wood/plexi/etc in the window that can have a bulkhead mount installed.
http://www.qsradio.com/Mounts.htm
Scroll down to PaneRelief for an example of some store bought solutions.
n8emr
what cable and how many? You can get cable ports to allow you to push it through the wall. Dont forget coming from under the floor or up an return air vent.
highmaster2
Cropwell, Alabama
I brought multiple runs of coax in the same openings that the freon lines come through from the heatpump - just resealed the opening with CoaxSeal. Once inside, I went under floors and over ceiling tiles 'til I got where I wanted to go.
