I am dealing with a problem where I am getting noise on my CB only when I cut on the AC, heat, defrost, or vent fan. Doesn't matter which selection I choose, the noise is present when the blower motor is on.
I was looking at the numerous threads on RR about troubleshooting the noise and tried the suggestions/solutions listed (installed an inline power filter to the B+ of the CB, checked grounding of the auto body, and tried the trick of a 0.1µF ceramic disc capacitor across the leads of the blower motor) with no luck eliminating my problem of noise. However, the solutions were helpful for me to finally able to determine that my noise issue is coming in from the antenna itself and not the incoming power wire.
I finally decided to google the topic and came across a forum where a guy had an issue of picking up noise only when he had to cut on his windshield-wipers and claimed that the only way he was able to solve the problem was to change out his fiberglass antenna (Wilson FGT or Firestik) and install a CB antenna that had a coil at the base of the antenna.
He claims that the center-loaded antennas will not work and that it has to be the base loaded antenna. His logic is that since the coil is at the bottom of the antenna (even though it's a part of the antenna) that the inline coil in the antenna will filter out noise from motors in the same mindset and mentality as those inline coil noise filter kits you install on the B+ wire going into the radio.
Does this make sense and is this true? I wanted to know before I take the gamble of purchasing a base-loaded coil antenna and swapping out my current fiberglass antenna.
Thanks for your help in advance.
