Base, Offset and Spacing
billy245
Michigan
Here in South Dakota, we have the Mot. 2 vhf system which on the Unidens requires me to put in the Base, Offset and Spacing to program in the system, along with the CC frequencies.
I don't see where to enter the Base, Offset and Spacing in the GRE 600. Am I missing something?
Also, when I put the CC frequency in on my ARC 500 Software 157.4125, it won't accept it and it goes to 157.400. Is there a way to set the step so it won't do this, or is it ok and shouldn't matter?
NDRADIONUT
FARGO ND
Find "enable Flex Step" For The 157.4125 Problem
Look For Edit Tt Tables At The Top Of The Column In The Trunk Systems Grid Double Click Where It Says To And You Can Enter Them
billy245
Michigan
OK, I found the offset, base and spacing. However, I can't find how to change the control channel step to bring it to 157.4125.
Also, where the base offset and spacing is, what is the high channel and lo channel? What does that mean?
Butelsoftware
Dayton Hamvention
You must enable flexstep in the software:
In ARC500 goto Global Settings , Software tab and tick 'Default Flexstep ON'. Now the software accepts 157.4125
Gommert
www.butelsoftware.com
mikey60
Oakland County Michigan
The Low Channel is always the same as the offset.
The High Channel will be one lower than the next offset on a multi-table system, or 759 if there are no other tables on VHF/UHF systems.
Mike
