base scanner antenna broke [but not really]
bloo
My scanner recently fell off its perch and now the antenna is in many little pieces.
I've reassembled the antenna. and the plug.
I just can't put the two together.
nothing is "broken" just disassembled.
so there's hope
so I can ask for heeeeeeeelp.
loose antenna connection in 2052
how do I get the cover off my 2052 after I remove the 4 screws? I want to see if its a loose connection as it works when I move the BNC back & forth , I know its the scanner, as the cable works okay on my other 2052also makes a growling noise?? tnx bob
Hoofy
Laurium, michigan
Sometimes there's a couple of plastic buttons that are placed in the holes on the side of the scanner where you would attach a mobile mounting bracket to the scanner. You have to remove the buttons and that should let the cover slide off the back of the scanner.
