base scanner antenna thats supports 27 mhz transmit
prcguy
Something like this small Discone with a sort of resonant whip for CB will not get far on CB. You can use a diplexer and transmit on the CB while receiving on the same antenna at the same time. There are a number of diplexers that have a port for HF to 30MHz for the CB, then another port that takes over somewhere below VHF and continues on up for the scanner. You can run quite a bit of power on CB transmit and not bother the scanner.
If you transmit on your CB when the scanner is connected - you're going to fry the scanner.
Antenna Broad Band Discone Scanner Base 25-1300 MHz. Tram 1411
CT
Right. He didn't mention using a Diplexer. Wonder if that's in his budget?
Good advice.
jaspence
Michigan
Depending on you antenna height and how far you want to be heard, even a decent 1/4 wave will do a reasonable job withour great expense.
iMONITOR
Silent Key
S.E. Michigan
Oops...thought he was asking about a radio instead of an antenna. I was paying bills on-line and got distracted. :oops:
prcguy
