Base Space and offset
briconellis
Valdosta, GA
Can someone help me figure out the base frequency space and offset for the freqs below? I am obviously not smart enough to figure out the trunked frequency table I got off of this site so I need some help from a pro.
Thank you
406.3500
406.7500
407.1500
407.5500
407.9500
408.2000
408.7500
409.1500
409.5500
409.7500
409.9500C
410.2000
413.3500
413.4000
414.7500
415.1500
415.5500
415.9500
416.3500
416.7500
417.1500
417.5500
418.3500
419.1500
The contol channel changes often.
mikey60
Oakland County Michigan
There's not enough information here to figure out the settings you're looking for.
What system is it that you are trying to figure out?
Where is it located?
Is it in the RR database?
These answers will help us to help you...
Mike
briconellis
Valdosta, GA
I have attached the RR data sheet for this system. Using the base freq settings on the sheet I am getting no hits at all and I know there is a lot of activity on the system. Additionally, The data sheet doesn't show half of the freqs that I am hearing.
I hope this helps.
If it not too much trouble I would love to know how to calculate the proper settings.
James
Transporter Room
I hope this helps.
are you using a pro96 or 2096? is the sytem 3600 or 9600?
if you are using either of above you might try offset 4096 or 8192. set table custom.
two mil. bases near me went to 9600 about a year ago. they have been removed from the database.
