Base, Spacing and offset for Ontario Fleetnet
xlq771
Ingersoll, ON
Why does the listings for the Ontario Fleetnet zone 1 now include 3 different Base, Spacing and Offset listings for the zone? How do I program my Pro-96 for this?
DaveH
Ottawa, Ont.
Apparently you will need programming software for this...Win96 or other. I've been told it's not possible
from the keyboard.
Dave
mciupa
Canadian DB Admin
Moderator
I'm here a lot
hemi said:
Should i program in the new spacing?
Not for Northumberland County. The only site out of the hundred or so sites that is in the
second range is Site 040 Toronto. It has one freq. that falls into the second range.
(152.0000 mHz). Does your radio have multi-range capacity ?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
For now it is not something to worry about, but when more and more freq's
are added into the 150 range, you will start missing parts of conversation and then it will require a radio that does multi- range base and offsets , such as a BC-296D which handles
three configurations.
So does this mean if I had a v file in my pro96 with the original offset and spacing for opp east it will not decode the control channel and must I reprogram that v file ?
