rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
I have a Uniden SDS200 Scanner connected to a Comet Discone Antenna, 25-1300 Mhz range, attic mounted. I realize it would work better if mounted on a mast outside, but that's not an option. The Discone is probably about 25' off the ground in the attic, and it receives VHF and UHF signals perfectly fine. The coax is RG8X in about a 100' length from the attic to the scanner. I plan to replace the coax with LMR400 to reduce losses that may be inherent in the RG8X.
I have a particular challenge receiving P25 signals via the Discone antenna off of one particular tower in my area, frequency range 773 Mhz. to 774 Mhz.. and the tower in question is located only about 6-10 miles away. But, the house is situated below the horizon, midway on a hill side, so geography may also contribute to blocking signals from this P25 tower. I receive signals from other P25 towers that are much further away, up to about 60 miles away, no problem.
I'm considering changing the antenna in the attic to the following:
DPD Productions Omni-X:
Or I'm also considering a Yagi that will provide some additional gain in one direction. I haven't researched a brand or model number for a good Yagi antenna for this purpose, one that would theoretically provide directional reception of this particular P25 tower. I would like to receive make and model recommendations from those that are having good performance with respect to P25 reception via a Yagi mounted in an attic.
The above DPD Productions "Omni-X" antenna comes very highly rated, and specifically when compared to a Discone antenna. DPD also manufactures vertical antennas that are specific to the 700 Mhz. frequency range that come highly rated for performance as well, but they're "omni-directional," but not wide banded. The Omni-X model above is omni-directional and wide banded, and I've read more positive reviews of the Omni-X antenna than the vertical antennas offered by DPD Productions.
I'm not sure, with the geographical issue of the antenna being below the horizon, if I would necessarily benefit from the directional characteristics of a Yagi versus the Omni-directional characteristics of the DPD Omni-X antenna above.
I'm open to testimonials relative to the DPD Productions Omni-X antenna above, as well as recommendations with respect to an attic mounted Yagi, if you believe a Yagi would benefit me more than the omni-directional "Omni-X" antenna, considering the geographical limitations of the antenna being situated slightly below the horizon.
